[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.in.ascii/main.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 10 04:21:44 EST 2007
Hello markus,
ANALYSIS
raster/r.in.ascii/main.c functions
main (Begins at: 36 Ends at: 271)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 98 | *** | MONSTER |
LOC: | 236 | ** | Warning |
1 metric are OUT OF RANGE!
file_cpy (Begins at: 274 Ends at: 302)
Complexity: | 5 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 29 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
