[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.in.arc/main.c |no clones | 0 monsters | 2 warnings
Sat Mar 10 04:21:44 EST 2007
Hello markus,
ANALYSIS
raster/r.in.arc/main.c functions
main (Begins at: 30 Ends at: 206)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     177 |     * |         |
at least 2 values are close to an outlier please consider revising code
file_cpy (Begins at: 209 Ends at: 235)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
