[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.his.rgb/openfiles.c |1 clones ( openfiles.c openfiles.c )| 0 monsters | 1 warnings
Fri Mar 16 07:53:23 EDT 2007
Hello brad,
ANALYSIS
imagery/i.his.rgb/openfiles.c functions
openfiles (Begins at: 7 Ends at: 46)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      36 |     * |         |
LOC:          |      40 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
  openfiles
In imagery/i.his.rgb/openfiles.c clones of  openfiles are:
	imagery/i.rgb.his/openfiles.c  openfiles
Threshold GRASS6 key metrics values at 2007-03-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
