[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.his.rgb/openfiles.c
|1 clones ( openfiles.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Mar 16 07:53:23 EDT 2007
Hello brad,
ANALYSIS
imagery/i.his.rgb/openfiles.c functions
openfiles (Begins at: 7 Ends at: 46)
Complexity: | 13 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 36 | * | |
LOC: | 40 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
openfiles
In imagery/i.his.rgb/openfiles.c clones of openfiles are:
imagery/i.rgb.his/openfiles.c openfiles
Threshold GRASS6 key metrics values at 2007-03-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
