[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.hull/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 24 03:14:06 EDT 2007
Hello martinl,
ANALYSIS
vector/v.hull/main.c functions
rightTurn (Begins at: 34 Ends at: 41)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
cmpPoints (Begins at: 43 Ends at: 53)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
convexHull (Begins at: 55 Ends at: 117)
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 63 | | OK |
metrics are OK
loadSiteCoordinates (Begins at: 122 Ends at: 165)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 44 | | OK |
metrics are OK
outputHull (Begins at: 173 Ends at: 214)
CalledNBR: | 13 | | OK |
LOC: | 42 | | OK |
metrics are OK
main (Begins at: 216 Ends at: 288)
Complexity: | 7 | | OK |
CalledNBR: | 34 | | OK |
LOC: | 73 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
