[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.to.points/main.c |no clones | 1 monsters | 2 warnings
Sat Mar 24 03:14:06 EDT 2007
Hello martinl,
ANALYSIS
vector/v.to.points/main.c functions
write_point (Begins at: 38 Ends at: 64)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      14 |       |      OK |
LOC:          |      27 |       |      OK |
at least 1 values are close to an outlier please consider revising code
write_line (Begins at: 66 Ends at: 143)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      78 |       |      OK |
main (Begins at: 145 Ends at: 356)
Complexity:   |      19 |     * |         |
CalledNBR:    |      93 |   *** | MONSTER |
LOC:          |     212 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
