[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/list.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 24 08:47:34 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/list.c functions
Vect_new_list (Begins at: 51 Ends at: 75)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 25 | | OK |
metrics are OK
Vect_reset_list (Begins at: 78 Ends at: 93)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 16 | | OK |
metrics are OK
Vect_destroy_list (Begins at: 96 Ends at: 120)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 25 | | OK |
metrics are OK
Vect_list_append (Begins at: 123 Ends at: 157)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 35 | | OK |
metrics are OK
Vect_list_append_list (Begins at: 160 Ends at: 182)
LOC: | 23 | | OK |
metrics are OK
Vect_list_delete (Begins at: 185 Ends at: 214)
LOC: | 30 | | OK |
metrics are OK
Vect_list_delete_list (Begins at: 217 Ends at: 239)
LOC: | 23 | | OK |
metrics are OK
Vect_val_in_list (Begins at: 242 Ends at: 255)
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
