[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.sun/main.c |no
clones | 3 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Mar 25 21:18:35 EDT 2007
Hello hamish,
ANALYSIS
raster/r.sun/main.c functions
main (Begins at: 132 Ends at: 465)
Complexity: | 24 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 109 | *** | MONSTER |
LOC: | 334 | *** | MONSTER |
2 metric are OUT OF RANGE!
INPUT (Begins at: 468 Ends at: 687)
Complexity: | 45 | *** | MONSTER |
ParamNBR: | 1 | | OK |
CalledNBR: | 81 | ** | Warning |
LOC: | 220 | ** | Warning |
1 metric are OUT OF RANGE!
OUTGR (Begins at: 689 Ends at: 819)
Complexity: | 29 | ** | Warning |
CalledNBR: | 50 | * | |
LOC: | 131 | * | |
at least 1 values are close to an outlier please consider revising code
com_par_const (Begins at: 822 Ends at: 859)
Complexity: | 6 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 38 | | OK |
metrics are OK
com_par (Begins at: 862 Ends at: 933)
Complexity: | 8 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 72 | | OK |
metrics are OK
lumcline2 (Begins at: 937 Ends at: 975)
Complexity: | 7 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 39 | | OK |
metrics are OK
joules2 (Begins at: 977 Ends at: 1107)
Complexity: | 22 | * | |
CalledNBR: | 11 | | OK |
LOC: | 131 | * | |
metrics are OK
new_point (Begins at: 1112 Ends at: 1121)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
where_is_point (Begins at: 1123 Ends at: 1148)
LOC: | 26 | | OK |
metrics are OK
cube (Begins at: 1150 Ends at: 1155)
LOC: | 6 | | OK |
metrics are OK
searching (Begins at: 1157 Ends at: 1183)
CalledNBR: | 3 | | OK |
LOC: | 27 | | OK |
metrics are OK
calculate (Begins at: 1189 Ends at: 1426)
CalledNBR: | 53 | * | |
LOC: | 238 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
com_sol_const (Begins at: 1428 Ends at: 1437)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
com_declin (Begins at: 1440 Ends at: 1450)
LOC: | 11 | | OK |
metrics are OK
brad (Begins at: 1452 Ends at: 1479)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 28 | | OK |
metrics are OK
drad (Begins at: 1481 Ends at: 1535)
LOC: | 55 | | OK |
metrics are OK
test (Begins at: 1537 Ends at: 1551)
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
