[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.segment/main.c |1 clones ( main.c )| 0 monsters | 1 warnings
Sun Mar 25 21:24:49 EDT 2007
Hello hamish,
ANALYSIS
vector/v.segment/main.c functions
main (Begins at: 27 Ends at: 189)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     163 |     * |         |
at least 1 values are close to an outlier please consider revising code
find_line (Begins at: 193 Ends at: 210)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  find_line
In vector/v.segment/main.c clones of  find_line are:
	vector/v.lrs/v.lrs.segment/main.c  find_line
Threshold GRASS6 key metrics values at 2007-03-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
