[GRASS-QA] GRASS QA: moritz |
./grass6/vector/v.transform/creat_trans.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 29 19:35:46 EDT 2007
Hello moritz,
ANALYSIS
vector/v.transform/creat_trans.c functions
create_transform_conversion (Begins at: 35 Ends at: 43)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
create_transform_from_user (Begins at: 46 Ends at: 86)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 41 | | OK |
metrics are OK
yes_no_quest (Begins at: 89 Ends at: 107)
Complexity: | 9 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 19 | | OK |
metrics are OK
create_transform_from_file (Begins at: 111 Ends at: 137)
CalledNBR: | 9 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
