[GRASS-QA] GRASS QA: hamish |
./grass6/display/d.paint.labels/do_labels.c |no clones | 0
monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Mar 30 03:05:29 EDT 2007
Hello hamish,
ANALYSIS
display/d.paint.labels/do_labels.c functions
initialize_options (Begins at: 44 Ends at: 65)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
do_labels (Begins at: 68 Ends at: 159)
Complexity: | 25 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 48 | * | |
LOC: | 92 | | OK |
metrics are OK
show_it (Begins at: 161 Ends at: 391)
Complexity: | 32 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 231 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
scan_ref (Begins at: 395 Ends at: 417)
Complexity: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
xmatch (Begins at: 419 Ends at: 435)
Complexity: | 6 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
ymatch (Begins at: 437 Ends at: 457)
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
