[GRASS-QA] GRASS QA: markus |
./grass6/vector/v.lrs/v.lrs.segment/main.c |1 clones ( main.c
)| 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue May 1 17:18:33 EDT 2007
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.segment/main.c functions
main (Begins at: 40 Ends at: 291)
Complexity: | 28 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 115 | *** | MONSTER |
LOC: | 252 | ** | Warning |
1 metric are OUT OF RANGE!
find_line (Begins at: 296 Ends at: 313)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
find_line
In vector/v.lrs/v.lrs.segment/main.c clones of find_line are:
vector/v.segment/main.c find_line
Threshold GRASS6 key metrics values at 2007-05-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
