[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.lrs/v.lrs.segment/main.c |1 clones ( main.c )| 1 monsters | 0 warnings
Tue May 1 18:40:01 EDT 2007
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.segment/main.c functions
main (Begins at: 40 Ends at: 291)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |     115 |   *** | MONSTER |
LOC:          |     252 |    ** | Warning |
1 metric are OUT OF RANGE!
find_line (Begins at: 296 Ends at: 313)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  find_line
In vector/v.lrs/v.lrs.segment/main.c clones of  find_line are:
	vector/v.segment/main.c  find_line
Threshold GRASS6 key metrics values at 2007-05-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
