[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Font.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu May 3 03:16:29 EDT 2007
Hello glynn,
ANALYSIS
lib/driver/Font.c functions
stroke_set (Begins at: 13 Ends at: 17)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
freetype_set (Begins at: 19 Ends at: 23)
LOC: | 5 | | OK |
metrics are OK
COM_Font_get (Begins at: 25 Ends at: 58)
Complexity: | 6 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 34 | | OK |
metrics are OK
COM_Font_init_charset (Begins at: 60 Ends at: 63)
Complexity: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
font_is_freetype (Begins at: 65 Ends at: 68)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
