[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Font.c |no clones | 0 monsters | 0 warnings
Thu May 3 03:16:29 EDT 2007
Hello glynn,
ANALYSIS
lib/driver/Font.c functions
stroke_set (Begins at: 13 Ends at: 17)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
freetype_set (Begins at: 19 Ends at: 23)
LOC:          |       5 |       |      OK |
metrics are OK
COM_Font_get (Begins at: 25 Ends at: 58)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
COM_Font_init_charset (Begins at: 60 Ends at: 63)
Complexity:   |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
font_is_freetype (Begins at: 65 Ends at: 68)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-03 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
