[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.flow/calc.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat May 5 05:30:06 EDT 2007
Hello glynn,
ANALYSIS
raster/r.flow/calc.c functions
height_angle_bounding_box (Begins at: 83 Ends at: 136)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 30 | | OK |
LOC: | 54 | | OK |
metrics are OK
on_map (Begins at: 138 Ends at: 144)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
add_to_line (Begins at: 151 Ends at: 159)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
rectify (Begins at: 164 Ends at: 190)
Complexity: | 6 | | OK |
LOC: | 27 | | OK |
metrics are OK
next_point (Begins at: 192 Ends at: 295)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 104 | | OK |
metrics are OK
calculate (Begins at: 301 Ends at: 404)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 104 | | OK |
metrics are OK
main (Begins at: 406 Ends at: 592)
Complexity: | 11 | | OK |
CalledNBR: | 62 | ** | Warning |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
