[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.univar2/sort.c |2
clones ( main.c main.c Driver.c com_proto.c loc_proto.c
sort.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat May 5 05:30:06 EDT 2007
Hello glynn,
ANALYSIS
raster/r.univar2/sort.c functions
downheap_int (Begins at: 20 Ends at: 37)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
downheap_float (Begins at: 42 Ends at: 60)
LOC: | 19 | | OK |
metrics are OK
downheap_double (Begins at: 65 Ends at: 83)
LOC: | 19 | | OK |
metrics are OK
heapsort_int (Begins at: 88 Ends at: 104)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 17 | | OK |
metrics are OK
heapsort_float (Begins at: 110 Ends at: 127)
LOC: | 18 | | OK |
metrics are OK
heapsort_double (Begins at: 132 Ends at: 149)
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
downheap_double downheap_float
In raster/r.univar2/sort.c clones of downheap_float are:
raster/r.univar2/sort.c downheap_double
In raster/r.univar2/sort.c clones of downheap_double are:
raster/r.univar2/sort.c downheap_float
Threshold GRASS6 key metrics values at 2007-05-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
