[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.edit/vertex.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat May 5 05:30:06 EDT 2007
Hello glynn,
ANALYSIS
vector/v.edit/vertex.c functions
do_move_vertex (Begins at: 29 Ends at: 127)
Complexity: | 8 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 21 | | OK |
LOC: | 99 | | OK |
at least 1 values are close to an outlier please consider revising code
do_add_vertex (Begins at: 129 Ends at: 210)
Complexity: | 7 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 23 | | OK |
LOC: | 82 | | OK |
metrics are OK
do_remove_vertex (Begins at: 218 Ends at: 295)
CalledNBR: | 20 | | OK |
LOC: | 78 | | OK |
metrics are OK
do_split (Begins at: 303 Ends at: 400)
CalledNBR: | 25 | | OK |
LOC: | 98 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
