[GRASS-QA] GRASS QA: paul | ./grass6/lib/driver/Font.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 7 19:50:58 EDT 2007
Hello paul,
ANALYSIS
lib/driver/Font.c functions
stroke_set (Begins at: 13 Ends at: 17)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
freetype_set (Begins at: 19 Ends at: 23)
LOC: | 5 | | OK |
metrics are OK
COM_Font_get (Begins at: 25 Ends at: 45)
Complexity: | 3 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 21 | | OK |
metrics are OK
COM_Font_init_charset (Begins at: 47 Ends at: 50)
Complexity: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
font_is_freetype (Begins at: 52 Ends at: 55)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
