[GRASS-QA] GRASS QA: paul | ./grass6/lib/driver/font2.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 7 19:50:58 EDT 2007
Hello paul,
ANALYSIS
lib/driver/font2.c functions
glyph_slot (Begins at: 30 Ends at: 43)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
coord_slots (Begins at: 45 Ends at: 60)
LOC: | 16 | | OK |
metrics are OK
read_hersh (Begins at: 62 Ends at: 125)
Complexity: | 12 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 64 | | OK |
metrics are OK
load_glyphs (Begins at: 127 Ends at: 141)
CalledNBR: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
read_fontmap (Begins at: 143 Ends at: 173)
Complexity: | 6 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
load_font (Begins at: 175 Ends at: 186)
Complexity: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
font_init (Begins at: 188 Ends at: 197)
LOC: | 10 | | OK |
metrics are OK
get_char_vects (Begins at: 199 Ends at: 223)
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 25 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
