[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Raster.c |no clones | 0 monsters | 0 warnings
Wed May 9 17:43:31 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Raster.c functions
scale (Begins at: 22 Ends at: 25)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
scale_fwd_y (Begins at: 27 Ends at: 30)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
scale_rev_x (Begins at: 32 Ends at: 35)
LOC:          |       4 |       |      OK |
metrics are OK
next_row (Begins at: 37 Ends at: 48)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
alloc_buffers (Begins at: 50 Ends at: 57)
LOC:          |       8 |       |      OK |
metrics are OK
PNG_begin_scaled_raster (Begins at: 59 Ends at: 73)
CalledNBR:    |       4 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
PNG_scaled_raster (Begins at: 75 Ends at: 113)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-09 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
