[GRASS-QA] GRASS QA: hamish |
./grass6/display/d.linegraph/linegraph.c |no clones | 2
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu May 10 03:28:08 EDT 2007
Hello hamish,
ANALYSIS
display/d.linegraph/linegraph.c functions
main (Begins at: 36 Ends at: 570)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 128 | *** | MONSTER |
LOC: | 535 | *** | MONSTER |
2 metric are OUT OF RANGE!
rem (Begins at: 572 Ends at: 576)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
death (Begins at: 580 Ends at: 585)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
