[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |no clones
	| 1 monsters | 9 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu May 10 03:28:08 EDT 2007
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 160 Ends at: 181)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 184 Ends at: 242)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 245 Ends at: 327)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 330 Ends at: 579)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |      32 |       |      OK |
LOC:          |     250 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 582 Ends at: 634)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 636 Ends at: 901)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     266 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 904 Ends at: 954)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 956 Ends at: 1142)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     187 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1144 Ends at: 1160)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1162 Ends at: 1376)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     215 |    ** | Warning |
G_usage_html (Begins at: 1378 Ends at: 1609)
Complexity:   |      43 |   *** | MONSTER |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     232 |    ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1611 Ends at: 1722)
Complexity:   |      22 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1724 Ends at: 1810)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      34 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
G_gui (Begins at: 1813 Ends at: 1842)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1845 Ends at: 1860)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1862 Ends at: 1892)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
show (Begins at: 1894 Ends at: 1907)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1909 Ends at: 1936)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1941 Ends at: 1950)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1952 Ends at: 2012)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 2014 Ends at: 2051)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 2053 Ends at: 2095)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2097 Ends at: 2163)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2165 Ends at: 2205)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2207 Ends at: 2234)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2236 Ends at: 2259)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2261 Ends at: 2324)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2326 Ends at: 2364)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2367 Ends at: 2423)
Complexity:   |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2425 Ends at: 2453)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2455 Ends at: 2463)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2465 Ends at: 2555)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2557 Ends at: 2587)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2589 Ends at: 2646)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2648 Ends at: 2750)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
