[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.linegraph/linegraph.c |no clones | 2 monsters | 0 warnings
Thu May 10 03:28:20 EDT 2007
Hello hamish,
ANALYSIS
display/d.linegraph/linegraph.c functions
main (Begins at: 36 Ends at: 570)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |     128 |   *** | MONSTER |
LOC:          |     535 |   *** | MONSTER |
2 metric are OUT OF RANGE!
rem (Begins at: 572 Ends at: 576)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
death (Begins at: 580 Ends at: 585)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
