[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.out.vtk/writeascii.c |1 clones ( writeascii.c )| 0 monsters | 4 warnings
Sun May 13 11:41:26 EDT 2007
Hello soeren,
ANALYSIS
raster/r.out.vtk/writeascii.c functions
get_raster_value_as_double (Begins at: 34 Ends at: 64)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
write_vtk_normal_header (Begins at: 70 Ends at: 96)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
write_vtk_structured_elevation_header (Begins at: 102 Ends at: 113)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
write_vtk_polygonal_elevation_header (Begins at: 118 Ends at: 128)
CalledNBR:    |       7 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
write_vtk_celldata_header (Begins at: 133 Ends at: 137)
LOC:          |       5 |       |      OK |
metrics are OK
write_vtk_pointdata_header (Begins at: 142 Ends at: 146)
LOC:          |       5 |       |      OK |
metrics are OK
write_vtk_structured_coordinates (Begins at: 153 Ends at: 201)
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      13 |       |      OK |
LOC:          |      49 |       |      OK |
at least 1 values are close to an outlier please consider revising code
write_vtk_polygonal_coordinates (Begins at: 207 Ends at: 314)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      23 |       |      OK |
LOC:          |     108 |       |      OK |
write_vtk_data (Begins at: 320 Ends at: 362)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
write_vtk_rgb_image_data (Begins at: 370 Ends at: 429)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      60 |       |      OK |
write_vtk_vector_data (Begins at: 436 Ends at: 487)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      52 |       |      OK |
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.out.vtk/writeascii.c clones of  get_raster_value_as_double are:
	raster3d/r3.out.vtk/writeVTKData.c  get_raster_value_as_double
	raster/r.to.rast3elev/main.c  get_raster_value_as_double
Threshold GRASS6 key metrics values at 2007-05-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
