[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.vect.chart/bar.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun May 13 11:50:41 EDT 2007
Hello hamish,
ANALYSIS
display/d.vect.chart/bar.c functions
bar (Begins at: 10 Ends at: 91)
Complexity: | 5 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 25 | | OK |
LOC: | 82 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
