[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.vect.chart/pie.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun May 13 11:50:41 EDT 2007
Hello hamish,
ANALYSIS
display/d.vect.chart/pie.c functions
pie (Begins at: 12 Ends at: 66)
Complexity: | 5 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 16 | | OK |
LOC: | 55 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
