[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.out.vtk/writeascii.c |1 clones (
writeascii.c )| 0 monsters | 4 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun May 13 13:53:22 EDT 2007
Hello markus,
ANALYSIS
raster/r.out.vtk/writeascii.c functions
get_raster_value_as_double (Begins at: 34 Ends at: 64)
Complexity: | 7 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 31 | | OK |
metrics are OK
write_vtk_normal_header (Begins at: 70 Ends at: 96)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 27 | | OK |
metrics are OK
write_vtk_structured_elevation_header (Begins at: 102 Ends at: 113)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 12 | | OK |
metrics are OK
write_vtk_polygonal_elevation_header (Begins at: 118 Ends at: 128)
CalledNBR: | 7 | | OK |
LOC: | 11 | | OK |
metrics are OK
write_vtk_celldata_header (Begins at: 133 Ends at: 137)
LOC: | 5 | | OK |
metrics are OK
write_vtk_pointdata_header (Begins at: 142 Ends at: 146)
LOC: | 5 | | OK |
metrics are OK
write_vtk_structured_coordinates (Begins at: 153 Ends at: 201)
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 13 | | OK |
LOC: | 49 | | OK |
at least 1 values are close to an outlier please consider revising code
write_vtk_polygonal_coordinates (Begins at: 207 Ends at: 314)
Complexity: | 6 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 23 | | OK |
LOC: | 108 | | OK |
write_vtk_data (Begins at: 320 Ends at: 362)
ParamNBR: | 6 | * | |
CalledNBR: | 16 | | OK |
LOC: | 43 | | OK |
metrics are OK
write_vtk_rgb_image_data (Begins at: 370 Ends at: 429)
Complexity: | 5 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 60 | | OK |
write_vtk_vector_data (Begins at: 436 Ends at: 487)
Complexity: | 4 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 52 | | OK |
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.out.vtk/writeascii.c clones of get_raster_value_as_double are:
raster3d/r3.out.vtk/writeVTKData.c get_raster_value_as_double
raster/r.to.rast3elev/main.c get_raster_value_as_double
Threshold GRASS6 key metrics values at 2007-05-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
