[GRASS-QA] GRASS QA: markus |
./grass6/vector/v.lrs/v.lrs.create/main.c |1 clones (
null_val.c main.c main.c )| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 14 21:47:16 EDT 2007
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.create/main.c functions
main (Begins at: 80 Ends at: 795)
Complexity: | 62 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 259 | *** | MONSTER |
LOC: | 716 | *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_along (Begins at: 797 Ends at: 809)
Complexity: | 5 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cmp_along
In vector/v.lrs/v.lrs.create/main.c clones of cmp_along are:
imagery/i.class/edge_order.c edge_order
Threshold GRASS6 key metrics values at 2007-05-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
