[GRASS-QA] GRASS QA: scott | ./grass6/imagery/i.fft/fftmain.c |no clones | 1 monsters | 0 warnings
Mon May 14 21:47:16 EDT 2007
Hello scott,
ANALYSIS
imagery/i.fft/fftmain.c functions
main (Begins at: 47 Ends at: 287)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      93 |   *** | MONSTER |
LOC:          |     241 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
