[GRASS-QA] GRASS QA: scott | ./grass6/vector/v.voronoi/vo_main.c |no clones | 0 monsters | 2 warnings
Mon May 14 21:47:16 EDT 2007
Hello scott,
ANALYSIS
vector/v.voronoi/vo_main.c functions
cmp (Begins at: 52 Ends at: 85)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
main (Begins at: 88 Ends at: 334)
Complexity:   |      19 |     * |         |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |     247 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
