[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.vpoints/digit.c |3
clones ( curses.c signature.c curses.c curses.c digit.c
curses.c digit.c curses.c digit.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 16 17:04:22 EDT 2007
Hello markus,
ANALYSIS
imagery/i.vpoints/digit.c functions
setup_digitizer (Begins at: 10 Ends at: 45)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 36 | | OK |
metrics are OK
setup (Begins at: 47 Ends at: 65)
Complexity: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
digitizer_point (Begins at: 67 Ends at: 101)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 35 | | OK |
metrics are OK
oops (Begins at: 103 Ends at: 109)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
no (Begins at: 111 Ends at: 115)
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
yes (Begins at: 117 Ends at: 121)
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
setup_digitizer setup digitizer_point
In imagery/i.vpoints/digit.c clones of digitizer_point are:
imagery/i.points/digit.c digitizer_point
imagery/i.ortho.photo/photo.2target/digit.c digitizer_point
In imagery/i.vpoints/digit.c clones of setup are:
imagery/i.points/digit.c setup
imagery/i.ortho.photo/photo.2target/digit.c setup
In imagery/i.vpoints/digit.c clones of setup_digitizer are:
imagery/i.points/digit.c setup_digitizer
imagery/i.ortho.photo/photo.2target/digit.c setup_digitizer
Threshold GRASS6 key metrics values at 2007-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
