[GRASS-QA] GRASS QA: markus |
./grass6/lib/vector/Vlib/break_polygons.c |no clones | 0
monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed May 16 17:04:22 EDT 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/break_polygons.c functions
srch (Begins at: 33 Ends at: 54)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
Vect_break_polygons (Begins at: 57 Ends at: 306)
Complexity: | 31 | ** | Warning |
ParamNBR: | 4 | | OK |
CalledNBR: | 57 | * | |
LOC: | 250 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
