[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Graph_set.c |no clones | 0 monsters | 0 warnings
Sun May 20 17:41:54 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Graph_set.c functions
write_prolog (Begins at: 54 Ends at: 97)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
write_setup (Begins at: 99 Ends at: 114)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
in2pt (Begins at: 116 Ends at: 119)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
swap (Begins at: 121 Ends at: 126)
LOC:          |       6 |       |      OK |
metrics are OK
get_paper (Begins at: 128 Ends at: 172)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
PS_Graph_set (Begins at: 174 Ends at: 224)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
output (Begins at: 226 Ends at: 233)
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
