[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.info/main.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon May 21 03:12:18 EDT 2007
Hello hamish,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 36 Ends at: 362)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 135 | *** | MONSTER |
LOC: | 327 | *** | MONSTER |
2 metric are OUT OF RANGE!
format_double (Begins at: 366 Ends at: 370)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
compose_line (Begins at: 373 Ends at: 388)
Complexity: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 16 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-05-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
