[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.what.color/main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Nov 12 10:36:30 EST 2007
Hello carlos,
ANALYSIS
raster/r.what.color/main.c functions
do_value (Begins at: 26 Ends at: 70)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 45 | | OK |
metrics are OK
main (Begins at: 72 Ends at: 162)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 91 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
