[GRASS-QA] GRASS QA: markus | ./grass6/general/g.region/cmd/main.c
|no clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Nov 12 13:01:48 EST 2007
Hello markus,
ANALYSIS
general/g.region/cmd/main.c functions
main (Begins at: 28 Ends at: 865)
Complexity: | 115 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 253 | *** | MONSTER |
LOC: | 838 | *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 867 Ends at: 873)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
nsew (Begins at: 875 Ends at: 881)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 7 | | OK |
metrics are OK
llinfo (Begins at: 883 Ends at: 891)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
