[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.coin/prnt_entry.c |no clones | 0 monsters | 0 warnings
Fri Nov 16 05:22:03 EST 2007
Hello hamish,
ANALYSIS
raster/r.coin/prnt_entry.c functions
print_entry (Begins at: 31 Ends at: 67)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
print_area (Begins at: 69 Ends at: 77)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
print_percent (Begins at: 79 Ends at: 84)
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
