[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.to.db/main.c |no clones | 0 monsters | 0 warnings
Fri Nov 16 06:09:29 EST 2007
Hello hamish,
ANALYSIS
vector/v.to.db/main.c functions
main (Begins at: 22 Ends at: 89)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
