[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.to.vect/main.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Nov 16 06:44:47 EST 2007
Hello hamish,
ANALYSIS
raster/r.to.vect/main.c functions
main (Begins at: 37 Ends at: 276)
Complexity: | 29 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 101 | *** | MONSTER |
LOC: | 240 | ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
