[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.to.vect/main.c |no clones | 1 monsters | 0 warnings
Fri Nov 16 06:44:48 EST 2007
Hello hamish,
ANALYSIS
raster/r.to.vect/main.c functions
main (Begins at: 37 Ends at: 276)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |     101 |   *** | MONSTER |
LOC:          |     240 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
