[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/snap.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 18 15:03:14 EST 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/snap.c functions
add_item (Begins at: 57 Ends at: 94)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 38 | | OK |
metrics are OK
Vect_snap_lines_list (Begins at: 97 Ends at: 403)
Complexity: | 28 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 75 | ** | Warning |
LOC: | 307 | *** | MONSTER |
1 metric are OUT OF RANGE!
sort_new (Begins at: 406 Ends at: 428)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 23 | | OK |
metrics are OK
Vect_snap_lines (Begins at: 431 Ends at: 467)
CalledNBR: | 12 | | OK |
LOC: | 37 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
