[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/field.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 18 15:03:13 EST 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/field.c functions
Vect_new_dblinks_struct (Begins at: 36 Ends at: 48)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
Vect_reset_dblinks (Begins at: 57 Ends at: 67)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 11 | | OK |
metrics are OK
Vect_map_add_dblink (Begins at: 70 Ends at: 97)
Complexity: | 5 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 10 | | OK |
LOC: | 28 | | OK |
at least 1 values are close to an outlier please consider revising code
Vect_map_del_dblink (Begins at: 106 Ends at: 141)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 36 | | OK |
metrics are OK
Vect_map_check_dblink (Begins at: 150 Ends at: 153)
LOC: | 4 | | OK |
metrics are OK
Vect_check_dblink (Begins at: 162 Ends at: 182)
LOC: | 21 | | OK |
metrics are OK
Vect_add_dblink (Begins at: 185 Ends at: 222)
Complexity: | 8 | | OK |
LOC: | 38 | | OK |
Vect_default_field_info (Begins at: 231 Ends at: 305)
ParamNBR: | 4 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 75 | | OK |
metrics are OK
Vect_get_dblink (Begins at: 308 Ends at: 340)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 33 | | OK |
metrics are OK
Vect_get_field (Begins at: 343 Ends at: 358)
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
Vect_read_dblinks (Begins at: 367 Ends at: 561)
Complexity: | 18 | * | |
CalledNBR: | 58 | * | |
LOC: | 195 | * | |
metrics are OK
Vect_write_dblinks (Begins at: 570 Ends at: 606)
CalledNBR: | 11 | | OK |
LOC: | 37 | | OK |
metrics are OK
Vect_subst_var (Begins at: 615 Ends at: 654)
CalledNBR: | 16 | | OK |
LOC: | 40 | | OK |
metrics are OK
Vect_set_db_updated (Begins at: 662 Ends at: 669)
CalledNBR: | 5 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
