[GRASS-QA] GRASS QA: markus |
./grass6/lib/vector/Vlib/break_lines.c |no clones | 0
monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 18 15:03:13 EST 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/break_lines.c functions
Vect_break_lines (Begins at: 37 Ends at: 278)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 4 | | OK |
CalledNBR: | 62 | ** | Warning |
LOC: | 242 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
