[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_base/isdir.c |no clones | 0 monsters | 0 warnings
Sun Nov 18 15:18:58 EST 2007
Hello markus,
ANALYSIS
lib/db/dbmi_base/isdir.c functions
db_isdir (Begins at: 12 Ends at: 20)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
