[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_base/dbmscap.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Nov 18 15:18:58 EST 2007
Hello markus,
ANALYSIS
lib/db/dbmi_base/dbmscap.c functions
dbmscap_filename (Begins at: 22 Ends at: 40)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
db_dbmscap_filename (Begins at: 49 Ends at: 52)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
db_has_dbms (Begins at: 61 Ends at: 64)
LOC: | 4 | | OK |
metrics are OK
db_copy_dbmscap_entry (Begins at: 73 Ends at: 92)
ParamNBR: | 2 | | OK |
LOC: | 20 | | OK |
metrics are OK
db_read_dbmscap (Begins at: 95 Ends at: 200)
CalledNBR: | 16 | | OK |
LOC: | 106 | | OK |
metrics are OK
add_entry (Begins at: 203 Ends at: 231)
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 29 | | OK |
metrics are OK
db_free_dbmscap (Begins at: 240 Ends at: 250)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-18 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
