[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.cats/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Nov 28 13:37:02 EST 2007
Hello carlos,
ANALYSIS
raster/r.cats/main.c functions
main (Begins at: 30 Ends at: 143)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 43 | * | |
LOC: | 114 | | OK |
metrics are OK
print_label (Begins at: 145 Ends at: 153)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
print_d_label (Begins at: 155 Ends at: 167)
CalledNBR: | 5 | | OK |
LOC: | 13 | | OK |
metrics are OK
scan_cats (Begins at: 169 Ends at: 182)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
scan_vals (Begins at: 184 Ends at: 191)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-11-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
