[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.mapcalc/map3.c |5 clones ( map3.c )| 0 monsters | 1 warnings
Wed Nov 28 13:37:02 EST 2007
Hello carlos,
ANALYSIS
raster/r.mapcalc/map3.c functions
setup_region (Begins at: 20 Ends at: 28)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
handle_to_fd (Begins at: 62 Ends at: 65)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
fd_to_handle (Begins at: 67 Ends at: 70)
LOC:          |       4 |       |      OK |
metrics are OK
read_row (Begins at: 72 Ends at: 118)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
write_row (Begins at: 120 Ends at: 169)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
compare_ints (Begins at: 173 Ends at: 176)
LOC:          |       4 |       |      OK |
metrics are OK
init_colors (Begins at: 178 Ends at: 190)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
init_cats (Begins at: 192 Ends at: 203)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
translate_from_colors (Begins at: 205 Ends at: 268)
CalledNBR:    |       3 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
translate_from_cats (Begins at: 270 Ends at: 330)
ParamNBR:     |       4 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
setup_map (Begins at: 332 Ends at: 334)
LOC:          |       3 |       |      OK |
metrics are OK
read_map (Begins at: 336 Ends at: 373)
ParamNBR:     |       6 |     * |         |
LOC:          |      38 |       |      OK |
metrics are OK
close_map (Begins at: 375 Ends at: 396)
Complexity:   |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
map_type (Begins at: 400 Ends at: 439)
Complexity:   |      12 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
open_map (Begins at: 441 Ends at: 530)
Complexity:   |      25 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
setup_maps (Begins at: 532 Ends at: 538)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
get_map_row (Begins at: 540 Ends at: 572)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      33 |       |      OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 574 Ends at: 582)
LOC:          |       9 |       |      OK |
metrics are OK
open_output_map (Begins at: 586 Ends at: 603)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
put_map_row (Begins at: 605 Ends at: 610)
ParamNBR:     |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
close_output_map (Begins at: 612 Ends at: 618)
LOC:          |       7 |       |      OK |
metrics are OK
unopen_output_map (Begins at: 620 Ends at: 623)
LOC:          |       4 |       |      OK |
metrics are OK
copy_cats (Begins at: 627 Ends at: 637)
LOC:          |      11 |       |      OK |
metrics are OK
copy_colors (Begins at: 639 Ends at: 649)
LOC:          |      11 |       |      OK |
metrics are OK
copy_history (Begins at: 651 Ends at: 653)
LOC:          |       3 |       |      OK |
metrics are OK
create_history (Begins at: 655 Ends at: 657)
LOC:          |       3 |       |      OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
  translate_from_colors  init_colors  translate_from_cats  copy_cats  copy_colors
In raster/r.mapcalc/map3.c clones of  copy_cats are:
	raster/r.mapcalc/map.c  copy_cats
In raster/r.mapcalc/map3.c clones of  translate_from_cats are:
	raster/r.mapcalc/map.c  translate_from_cats
In raster/r.mapcalc/map3.c clones of  init_colors are:
	raster/r.mapcalc/map.c  init_colors
In raster/r.mapcalc/map3.c clones of  copy_colors are:
	raster/r.mapcalc/map.c  copy_colors
In raster/r.mapcalc/map3.c clones of  translate_from_colors are:
	raster/r.mapcalc/map.c  translate_from_colors
Threshold GRASS6 key metrics values at 2007-11-28 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
