[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.mapcalc/map.c |5
clones ( map3.c map.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Nov 28 13:37:02 EST 2007
Hello carlos,
ANALYSIS
raster/r.mapcalc/map.c functions
setup_region (Begins at: 20 Ends at: 27)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
compare_ints (Begins at: 66 Ends at: 69)
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
init_colors (Begins at: 71 Ends at: 83)
Complexity: | 6 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 13 | | OK |
metrics are OK
init_cats (Begins at: 85 Ends at: 96)
Complexity: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 12 | | OK |
metrics are OK
translate_from_colors (Begins at: 98 Ends at: 161)
Complexity: | 11 | | OK |
ParamNBR: | 5 | * | |
LOC: | 64 | | OK |
metrics are OK
translate_from_cats (Begins at: 163 Ends at: 223)
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 61 | | OK |
metrics are OK
set_read_row_type (Begins at: 225 Ends at: 228)
LOC: | 4 | | OK |
metrics are OK
read_row (Begins at: 230 Ends at: 236)
Complexity: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
setup_map (Begins at: 238 Ends at: 254)
LOC: | 17 | | OK |
metrics are OK
read_map (Begins at: 256 Ends at: 304)
Complexity: | 10 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 49 | | OK |
metrics are OK
close_map (Begins at: 306 Ends at: 333)
LOC: | 28 | | OK |
metrics are OK
map_type (Begins at: 337 Ends at: 363)
LOC: | 27 | | OK |
metrics are OK
open_map (Begins at: 365 Ends at: 450)
Complexity: | 25 | * | |
CalledNBR: | 15 | | OK |
LOC: | 86 | | OK |
metrics are OK
setup_maps (Begins at: 452 Ends at: 458)
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
get_map_row (Begins at: 460 Ends at: 493)
Complexity: | 13 | | OK |
ParamNBR: | 7 | ** | Warning |
LOC: | 34 | | OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 495 Ends at: 503)
LOC: | 9 | | OK |
metrics are OK
open_output_map (Begins at: 507 Ends at: 516)
LOC: | 10 | | OK |
metrics are OK
put_map_row (Begins at: 518 Ends at: 522)
ParamNBR: | 3 | | OK |
LOC: | 5 | | OK |
metrics are OK
close_output_map (Begins at: 524 Ends at: 528)
LOC: | 5 | | OK |
metrics are OK
unopen_output_map (Begins at: 530 Ends at: 533)
LOC: | 4 | | OK |
metrics are OK
copy_cats (Begins at: 537 Ends at: 547)
LOC: | 11 | | OK |
metrics are OK
copy_colors (Begins at: 549 Ends at: 559)
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
copy_history (Begins at: 561 Ends at: 570)
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
create_history (Begins at: 572 Ends at: 615)
Complexity: | 4 | | OK |
LOC: | 44 | | OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
translate_from_colors init_colors translate_from_cats copy_cats copy_colors
In raster/r.mapcalc/map.c clones of copy_cats are:
raster/r.mapcalc/map3.c copy_cats
In raster/r.mapcalc/map.c clones of translate_from_cats are:
raster/r.mapcalc/map3.c translate_from_cats
In raster/r.mapcalc/map.c clones of init_colors are:
raster/r.mapcalc/map3.c init_colors
In raster/r.mapcalc/map.c clones of copy_colors are:
raster/r.mapcalc/map3.c copy_colors
In raster/r.mapcalc/map.c clones of translate_from_colors are:
raster/r.mapcalc/map3.c translate_from_colors
Threshold GRASS6 key metrics values at 2007-11-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
