Hello carlos,
ANALYSIS
vector/v.in.ascii/a2b.c functions
asc_to_bin (Begins at: 9 Ends at: 162)
Complexity: | 29 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 40 | * | |
LOC: | 154 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
